It is currently Fri Jul 11, 2025 4:03 am
 Post subject: Primary Gear rebore
PostPosted: Sun Jul 28, 2019 8:45 am
Looking for someone to line bore bushes in a primary gear on 1275 motor - pre A Plus series. Fitted with new bushes and requires machining to suit crankshaft. Prefer Geelong but will post to Melbs. Thanks in advance.
 Post subject: Re: Primary Gear rebore
PostPosted: Sun Jul 28, 2019 7:16 pm
Hi, don't forget to measure the crankshaft diameters with a micrometer. The larger diameter is nearly always undersize, and if you machine it to standard size you will already be too large in the bush. Cheers Lindsay. I do have the name of a good machinist, who has done many for me if you are stuck, but you would have to post to Melbourne.
1959 Austin A40 Farina fun car
1965 Mk1 Cooper S restored
1970 Colt 1100F SS restored
2014 Mitsubishi Imiev fully electric daily driver
1948 Allard M coupe Olds 215 v8 project
1971 Twin cam Escort ex Uk championship winning rally car project
PostPosted: Mon Jul 29, 2019 2:39 pm
Thanks Lindsey, we are aware of the undersize issue. Would appreciate the name and contact details of the machinist in Melbourne. Regards Chris
