It is currently Sat Jul 12, 2025 4:18 pm
 Post subject: internal gear linkage
PostPosted: Thu Apr 26, 2018 4:04 am
Milatsmadmini
Anyone running one? Did you make it yourself or buy the KAD kit?
PostPosted: Thu Apr 26, 2018 12:33 pm
Yes. Mine is standard rod change base with KAD kit. Goes straight through the 850 pudding stirrer hole in floorpan. The KAD kit internal mounting bracket is designed for UK MK 4 floorpan so you need to add brackets to properly fit Aus floorpan.
Once adjusted it is pretty good. It was jumping out of gear on the rough ground in the motorkhana, but that never happens on smooth tarmac. Would need rigid engine mounts and steadies to fully prevent it on rough ground i think.
PostPosted: Thu Apr 26, 2018 10:53 pm
Milatsmadmini
ooooooh what sort of extra brackets are needed? Any pictures of your setup per chance sir?
PostPosted: Wed Jun 26, 2019 8:29 pm
Are these road legal? Insurance issue?
Sent from my SM-G950F using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
PostPosted: Thu Jun 27, 2019 3:58 pm
no, why would it? it doesn't make the car any less safe or give any performance increase
PostPosted: Thu Jun 27, 2019 4:06 pm
Cos insurance will void you for a loose rearvision mirror if they could. Good to know.
PostPosted: Thu Jun 27, 2019 4:56 pm
Milatsmadmini
Has anyone put one of these in a moke? Or made one as a diy?
PostPosted: Fri Jun 28, 2019 7:34 am
Another hijack will it go into a remote gearbox?
PostPosted: Fri Jun 28, 2019 8:04 am
Back in the day a UK company called SPQR made an internal conversion for magic wand gearboxes, you can see more photos in the link here: http://www.mini-house.com/SPQR001.htm
Any reason you’d want to modify the remote shifter?
I’m sure you could modify the rod change style to fit a Moke, as long as the bracket is secure to the floor and the shifting rod is the right length. You can see a homemade one here:
http://www.theminiforum.co.uk/forums/to ... omsearch=1
PostPosted: Fri Jun 28, 2019 8:20 am
Mine isn't actually remote, it's a wand into a remote housing like a moke. I just like the junky aesthetic. i like that spqr thing!
PostPosted: Fri Jun 28, 2019 10:12 am
Ah that's the infamous puddin' stirrer gearshift, not to be confused with the 850's magic wand. ;)
