It is currently Sun Jul 13, 2025 1:23 pm
PostPosted: Thu Jun 06, 2019 8:39 am
I am replacing my Diagonal Tie Rod bushings and would like to know how does the washer on the side where the nut goes is facing? it is not a flat washer but a washer the is curved or like a bowl shape. Which side is facing the bushing the closed or open side of the washer. Sorry this is the best I could explain it.
I hope some of this picture helps.
This looks like there are two washers a flat one and a curved one?
1973 Clubman GT - YG2S8 1637
PostPosted: Thu Jun 06, 2019 11:40 am
20 is cup washer, concave face to bush
21 is flat washer
Diagram only shows one bush of the two per side
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Thu Jun 06, 2019 11:54 am
21 is flat washer
Thank you no wonder they also sell the flat one, thanks
PostPosted: Thu Jun 06, 2019 6:50 pm
Looks like you have the "correct" pairing of one poly bush with one rubber version. Don't forget to put the poly item at the front....
Cheers, Ian
