It is currently Thu Jul 10, 2025 8:55 pm
PostPosted: Fri May 24, 2019 8:31 am
So have been tackling this and some might find it interesting ..
I havd 3 seals , all measured differently :
2 red = 54 ish mm id
1 black = 53mm id
Black did not like the primary gear. Od was fine but inner would not fit on .
Homemade seal press: 60m pipe joiner coupled with gear change cap and crank bolt .
Works a treat if you have the right seal that’s wants to fit .
Thought the red did until I saw this
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri May 24, 2019 12:49 pm
oil up the seal and the tape over the primary gear
PostPosted: Fri May 24, 2019 10:02 pm
Try using pvc duct tape instead of masking tape. It will slide easier.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri May 24, 2019 10:13 pm
Thanks scoop and Simon , will try when I get some more seals
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Fri May 24, 2019 10:43 pm
I've never had any dramas with the red seals.
PostPosted: Sat May 25, 2019 7:28 am
I like your idea of the seal press. Are you able to show how it's put together/made?
PostPosted: Sat May 25, 2019 3:56 pm
It is really easy with the right tools - 18G1098 is a sleave that enables you to slide the lip of the seal all the way along the primary gear and over the shoulder that you seem to be catching them on. It also has a handy taper that eases the seal out to the shoulder diameter before you slide it along.
If you want to make your own version, just get a nice taper for the seal lip to get out to the shoulder diameter and slide straight onto the seal running surface, this is the key.
PostPosted: Wed Jun 12, 2019 9:47 pm
Seal tool in action .
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Jun 13, 2019 12:27 pm
that's a snazzy piece of work!
PostPosted: Thu Jun 13, 2019 4:18 pm
Haha yes it is ! A bit of bling that’s used literally for 2 mins ....
it’s available for anyone anyone who wants to use it .. postage only
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Jun 13, 2019 9:42 pm
Hey Simon,
Did you buy the tool from minisport?
PostPosted: Wed Jul 10, 2019 9:23 am
I was lucky , I scored these from an old Pommy BMC mechanic a few yrs ago,
PostPosted: Wed Jul 10, 2019 10:57 am
I made the same tools, years ago. :mrgreen:
Users browsing this forum: BBY755, mincs1 and 81 guests
