It is currently Sat Jul 12, 2025 2:44 pm
 Post subject: twin carbies 1970 cs
PostPosted: Tue May 14, 2019 2:42 pm
I have noticed the rh carbie has a small hole about 3mm dia below the bowl filler brass tube. Anyone know what the hole is for, seems to be if the needle sticks fuel will come out of this hole.
Allen
 Post subject: Re: twin carbies 1970 cs
PostPosted: Tue May 14, 2019 2:49 pm
Yes, that’s the vent and also for the overflow. If you block if it won’t fill with fuel. The later float lids had a tube there so you could use a hose to route the overflow away from the exhaust manifold
There should be a little cover like the photos here. There is also a photo of the later style ones
https://sites.google.com/site/fifersrel ... -lids-info
PostPosted: Tue May 14, 2019 5:38 pm
TY Timmie the lh carbie does not have a hole. Should I leave as is on change to a later style for safety ?
Allen
PostPosted: Mon May 20, 2019 11:15 am
There must be a vent hole there somewhere, or the air can't get out. So the bowl won't fill with fuel, as Timmy says...
