It is currently Fri Jul 11, 2025 5:47 am
 Post subject: Fuel guage question
PostPosted: Wed May 08, 2019 9:39 am
Should the fuel guage work with the ignition off. My '69 Mk2 S battery is not holding charge if not started for a week or so. On checking the wiring diagram the B terminal on the voltage regulator gets power from the wiper motor. Along with the fuel guage, the wipers also operate without ignition on.
I am wandering whether this is where the battery drain is occurring before I take the battery back to the supplier for warranty.
Any thoughts?
 Post subject: Re: Fuel guage question
PostPosted: Wed May 08, 2019 12:23 pm
no, it shouldn't work with the ignition off, and yes, that would drain the battery. The +12v wire is connected to the wrong fuse
PostPosted: Wed May 08, 2019 12:26 pm
Alan,
As Simon said, fuel gauge shouldn't work with ignition off, neither should the wipers.
Clive
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Wed May 08, 2019 1:55 pm
Thanks. All fixed, yes, the 12v feed was connected to the wrong fuse.
Users browsing this forum: Bing [Bot] and 100 guests
