It is currently Sat Jul 12, 2025 12:21 pm
 Post subject: Loose ignition barrel
PostPosted: Sun May 05, 2019 6:59 pm
Daffodil 1275
Hi, today I turned off my ignition but unlike other days, the barrel outer chrome housing came away with the key. I have screwed the chrome housing back on but it seems a little loose. Is there something at the back that needs tightening & if so the best way to get to it. Can’t seem to find anything in my workshop manual. 69 Cooper S M2. Any advice appreciated
Life advice
Don't wait for the storm to pass
Learn to dance in the rain
OR
Go drive your MINI
PostPosted: Sun May 05, 2019 10:12 pm
Behind the panel there is a half nut and washer that can be set to control the amount of thread on the ignition switch sticking out.
On the outside of the panel there is a thin wavy washer (just visible in the photo - against the panel); then the chrome sleeve; then the chrome lock nut with 2 slots.
The thin wavy washer provides some tension to hold everything tight.
Hope that's some help.
PostPosted: Sun May 05, 2019 10:48 pm
Daffodil 1275
It appears it is the washer that is missing as I only have the sleeve & lock nut..... will have a good look around the floor where it has probably dropped. Until your reply I didn’t know it was missing so thanks for the reply
Life advice
OR
Go drive your MINI
