It is currently Sat Jul 12, 2025 10:48 pm
 Post subject: Key barrel set
PostPosted: Tue Apr 16, 2019 9:33 am
Does anyone know if these will fit the Aussie wind up window doors? Mine are buggered....
http://www.minispares.com/product/Classic/27H9634.aspx
Alternatively, is there any way to repair them. The little nub on the end that turns the locking pin has worn/broken off.
67 Van, 1275cc
 Post subject: Re: Key barrel set
PostPosted: Tue Apr 16, 2019 1:23 pm
I think John Smidt told me once that the boot lock tumbler can be modified to fit Oz windup door locks.
The UK door tumblers apparently don't fit.
Edit
Yes you can repair the little pin thing. I fixed a boot lock one by carefully drilling it out then pressing in a pin made from a bit of nickel bronze welding rod. I think it was 2.4 or 2.5mm diameter. I Loctited it as well.
Last edited by drmini in aust on Tue Apr 16, 2019 1:27 pm, edited 1 time in total.
PostPosted: Tue Apr 16, 2019 1:27 pm
thanks Doc.
Going to see if I can fix mine, otherwise i'll try the boot lock method.
67 Van, 1275cc
PostPosted: Tue Apr 16, 2019 2:50 pm
As Doc said, repairable. Broke pin off due to brute force and ignorance. Drilled hole in barrel, tapped thread and used small screw to repair. Loctited and cut off head, still operational.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Tue Apr 16, 2019 2:58 pm
You absolute champion! Exactly what I need to do to get mine fixed!
67 Van, 1275cc
