It is currently Fri Jul 18, 2025 7:33 am
PostPosted: Wed Mar 20, 2019 9:38 pm
Hi chaps, hoping someone can tell me if the sender to suit an electronic temp gauge (fitted in the head casting near the thermostat) needs a copper washer or sensor sealant?
It’s NOT a tapered thread on the sensor.
cheers,
Silas
PostPosted: Wed Mar 20, 2019 10:13 pm
No. Just screw it in, it seats on a tapered face in the head.
PostPosted: Thu Mar 21, 2019 7:36 am
A low strength thread sealant helps if you have any leaks there. I use a low-strength thread sealant in most cases just to be sure.
PostPosted: Thu Mar 21, 2019 7:39 am
Brilliant, Thanks doc!
