It is currently Sat Jul 19, 2025 8:44 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
 Post subject: BPR5ES or BPR6ES
PostPosted: Sun Sep 16, 2018 3:44 pm
I'm changing the spark plugs, engine is 1275 with twin 1.25 SUs and very mild cam, what is the consensus on the best spark plugs?
 Post subject: Re: BPR5ES or BPR6ES
PostPosted: Sun Sep 16, 2018 4:23 pm
Champion N9Y or N9YC cooper core and you can still buy them.
PostPosted: Sun Sep 16, 2018 5:07 pm
One two many "o"s and one too few "p"s?
PostPosted: Sun Sep 16, 2018 8:03 pm
Are these any good?
https://www.ebay.com/itm/CHAMPION-SPARK ... 2749.l2649
PostPosted: Sun Sep 16, 2018 9:29 pm
NGK BPR5ES these days.
Rumour has it resistor plugs give a hotter spark,
BP recommend 1 heat range hotter for unleaded fuel,
NGK plugs are made in Japan, not Mexico or elsewhere.
PostPosted: Sun Sep 16, 2018 10:01 pm
NGK all the way, have used them in race cars for years. no probs.
Why is it the things that make me tick, are also the things that make me go boom?
PostPosted: Sun Sep 16, 2018 11:35 pm
NGK BP5ES over here, 10:1cr 1275 with a cam.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Mon Sep 17, 2018 9:23 am
yeah, 5's are what you want
PostPosted: Mon Sep 17, 2018 12:43 pm
I previously had problems with plug fouling in the queue for the motorkhana where it idles for ages (maybe 15-30 minutes) and only has a 30 second or less run before waiting another 15-30 minutes in the queue. Is it worth going one heat range hotter (i.e. BP6ES)?
PostPosted: Mon Sep 17, 2018 12:51 pm
5 is hotter than 6
PostPosted: Mon Sep 17, 2018 1:06 pm
Not sure letting an A series idle for prolonged periods is such a good idea.
Less/insufficient splash lubrication for the bores/pistons at low engine speeds.
But waiting in a 'khan queue maybe no options, unless you push it along!
PostPosted: Thu Feb 28, 2019 3:27 pm
I was using a BP6ES and it fouls after idling for a while so now I am going to try a BPR4ES. My question is on my 1973 Clubman GT do I use 91 or 87 unleaded fuel or do I use a lead additive and which octane fuel rating? thanks
1973 Clubman GT - YG2S8 1637
PostPosted: Thu Feb 28, 2019 3:35 pm
Use 95 or 98 fuel. Why are you jumping BP5 and going straight to BP4?
PostPosted: Thu Feb 28, 2019 4:23 pm
I think Guam would use the same octane rating as the US:
98 RON (AUS) is about the same as 93 AKI (US)
95 RON (AUS) is about the same as 91 AKI (US)
PostPosted: Thu Feb 28, 2019 4:51 pm
I am tired of buying plugs so I thought 4 should be better. The 6 lasted for a few months. Yes we have 87 and 91 AKI. No 93. Do I need to add a lead substitute? I have not been using one.
Users browsing this forum: Bing [Bot] and 84 guests
