It is currently Sat Jul 19, 2025 8:20 pm
 Post subject: Re: Supercharged 1275
PostPosted: Sun Feb 03, 2019 12:04 pm
ausdino wrote:
Chris.Williams wrote:
zulu_warrior1976 wrote:
Mind if I ask where you got the kit? Is it easy to fit?
It’s a zmax kit from the Uk.
Very simple to fit.
Not the Vmaxscart kit ? Looks the same.
Yes sorry Vmax kit, my smartphone isn’t always so smart.
PostPosted: Tue Feb 05, 2019 7:31 pm
Nice, looks great, well done :)
What boost are you running?
Doe sit run well?
PostPosted: Wed Feb 06, 2019 7:08 am
Doe sit run well?
Hi, currently running 10 psi, have ordered a reduction pulley to give it between 5-6 more.
After a bit of fiddling with jets and chokes it seems to be running very well.
I’ll be fitting a water/methanol injection kit to cool the charge and make the extra boost safe.
PostPosted: Thu Feb 07, 2019 7:00 pm
:D Hi Chris, looks great. What chokes do you have in the Weber? My VMAXSCART kit was running very rich on cruise with 30mm chokes as supplied in the kit. I have now fitted 34mm chokes and it is running much better and hovers around 10 to 11 AFR when cruising. About 13:1 AFR on idle and 14:1 AFR under power. With the standard pulley I get 5lb boost at 2000 rpm full throttle with a max of 13lb boost at 6500rpm. The car has been dyno Ed a few times and makes almost 90hp ATW,s which gives a fun drive. I am sure you are enjoying your car on the brilliant NZ roads. :D
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Feb 07, 2019 7:13 pm
I also had 30mm chokes, I changed my idle jet to lower my cruse fuel ratio, that’s the circuit they are responsible for. I fitted 28mm chokes to speed up airflow as I had the dreaded Weber cough.
Would bog down when you planted your foot, changed my idle jets for larger ones, which also helped.
I was getting 13lb from about 4000rpm but then changed both my head and full exhaust to more free flowing which has bought my boost down.
I’ll fix this with a 17% reduction pulley.
It’s definitely fun to drive.
Got any pictures of yours?
Here’s the outside of my Clubby
PostPosted: Thu Feb 07, 2019 7:33 pm
Checkout “1275LS conversion project”
I am note sure how to post a link and I need to update with some more recent photos.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu Feb 07, 2019 9:11 pm
don't run that for too long, good recipe for melted pistons
PostPosted: Thu Feb 07, 2019 9:19 pm
This was my original setup with SU which went Ok but had a few small issues due to the length of the inlet pipe. Great for cruising but difficult in stop start traffic
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu Feb 07, 2019 9:35 pm
Been like that for 6 years and still going strong. The AFR does jump around a lot unless idling or cruising
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Fri Feb 08, 2019 3:18 am
Idle 13.5-14 :1 afr
Cruise 13.5-14.5:1 afr
Full load 12-12.5 :1 air fuel ratio
This is how mine ended up
PostPosted: Sun Feb 10, 2019 12:04 pm
Took the mini to a local show
https://youtu.be/2yQi8gmgTO0 This is the drive home
Users browsing this forum: Bing [Bot] and 63 guests
