It is currently Sun Jul 20, 2025 2:01 am
 Post subject: valve spring tester
PostPosted: Fri Feb 01, 2019 7:54 pm
hi i have been lucky enough to purchase a warren and brown valve spring tester. has anyone had any experience in maintaining one. it appears to work off hydraulic pressure. is this correct. can i change the oil in it.
thanks Kiwiinwgtn
Sent from my SM-J530Y using Tapatalk
 Post subject: Re: valve spring tester
PostPosted: Fri Feb 01, 2019 7:56 pm
thanks Kiwiinwgtn
photos added
PostPosted: Fri Feb 01, 2019 7:59 pm
Nice.
PostPosted: Sat Feb 02, 2019 7:03 am
thanks Kiwiinwgtn
W&B have moved from Foot-us-scray...but why not ask them the question :idea:
https://www.warrenandbrown.com.au/
PostPosted: Sat Feb 02, 2019 7:15 am
9YaTaH wrote:
thanks Kiwiinwgtn
thanks thought they where long gone. will get in in contact
PostPosted: Sat Feb 02, 2019 7:42 am
Can't see why you couldn't replace the oil, the gauge does the indication, just ask if Tellus (for example) would be OK [should be an oil to use sticker etc on the unit itself]
PostPosted: Sat Feb 02, 2019 9:18 am
Do a Google search on warren and brown valve spring tester. There's a few hits and some might be helpful.
In this one the owner says he replaced the seal and added oil to get his working.
https://www.speedtalk.com/forum/viewtopic.php?t=52326
PostPosted: Wed Feb 06, 2019 8:16 pm
You will need to buy a Calibration spring to test its calibration at known heights and pressures.
https://www.powerhouseproducts.com/cali ... pring.html
PostPosted: Wed Feb 06, 2019 8:28 pm
yes good point. will get one to test the machine. thanks for the link
