It is currently Sun Jul 20, 2025 1:45 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jan 31, 2019 5:43 pm
WasabiPimpNinja wrote:
Most 1.25" Carbs I've rebuilt have not required bushes. In the 1.25" the bushing area where the throttle shaft runs through is generally the same cast material as the rest of the carb body as opposed to having a brass bush in there, so the shaft tends to wear before the "bushes". On the 1.5" and 1.75" carbs there is a brass bush in there that the throttle shaft runs on, brass on brass wears fairly evenly so if you have a worn shaft, you generally have worn bushes too. But quite often you can also get away with just replacing the shaft.
Good to know. I am about to do my 1.25's. Just had to get use of a drill press.
PostPosted: Thu Jan 31, 2019 9:38 pm
AEG163job wrote:
1071 S wrote:
I'd be interested to come by and help 8) ...or is that observe..I have feeling mine could do with a touch up.... so a little practice would be quite welcome.
Cheers, Ian
OK mate, how good are you with a drill press? :lol:
I’ll be better once I practice on yours :twisted:
PostPosted: Thu Jan 31, 2019 9:52 pm
May need a new drill press. Bit of wobble in the old one :( Made in Taiwan, but it has served me well over the last 20 years.
Probably also the handiest electrical tool I've used since I got it.
Any good brand recommendations? Anything Made in China (the Communist one), forget it. I do have some principles :roll:
