It is currently Sat Jul 19, 2025 12:25 pm
 Post subject: Supercharged 1275
PostPosted: Thu Jan 31, 2019 2:19 am
Hey all,
Thought I’d put up a picture of my supercharged 1275 Clubman for all to see.
 Post subject: Re: Supercharged 1275
PostPosted: Thu Jan 31, 2019 5:55 am
Hi Chris,
Nice set up!
PostPosted: Thu Jan 31, 2019 7:12 am
That’s cool! Did you fit all that yourself?
Zulu...
1967 mini Cooper S
PostPosted: Thu Jan 31, 2019 7:26 am
Toy444 wrote:
Hi Chris,
Nice set up!
Thanks
PostPosted: Thu Jan 31, 2019 7:27 am
Thanks, yes rebuilt the motor and fitted the charger kit myself.
It’s an m62 Eaton running a 40 dcoe.
PostPosted: Thu Jan 31, 2019 7:30 am
Mind if I ask where you got the kit? Is it easy to fit?
Zulu...
1967 mini Cooper S
PostPosted: Thu Jan 31, 2019 9:37 am
using a weber is a better idea than the silly uphill pipe for the SU implementation - and it has a throttle pump
PostPosted: Thu Jan 31, 2019 10:29 am
That's a very neat install! All seems to fit in very well.
PostPosted: Thu Jan 31, 2019 11:22 am
Now that's just showing off. :lol:
Very nice and well thought out.
Is the green stuff coolant? What's it plumbed to and from?
Chris.Williams wrote:
Hey all,
PostPosted: Thu Jan 31, 2019 11:28 am
No oil cooler required?
What is the compression ratio?
PostPosted: Thu Jan 31, 2019 4:44 pm
It’s a zmax kit from the Uk.
Very simple to fit.
PostPosted: Thu Jan 31, 2019 4:46 pm
Thanks very much, there is more room behind the charger then there ever was with twin su’s.
Having the clubman she’ll also helps.
PostPosted: Thu Jan 31, 2019 4:52 pm
Hey all,
Yes green stuff is coolant, runs from a temperature controlled pump/reservoir through a radiator mounted behind my grill then through a plate between the charger and the manifold.
Effectively a chargecooler
PostPosted: Thu Jan 31, 2019 4:57 pm
I have an oil cooler, not needed it yet.
Compression is 8.7:1, I’m running 98 octane fuel and will more then likely add a meth/water injection kit.
PostPosted: Sat Feb 02, 2019 10:46 pm
Very simple to fit.
Not the Vmaxscart kit ? Looks the same.
Users browsing this forum: Bing [Bot] and 77 guests
