It is currently Sat Jul 19, 2025 12:13 pm
PostPosted: Fri Jan 25, 2019 10:40 pm
Hi all,
Just replaced my Lucas 9 tooth starter for a new 10 tooth. Some suggest its a non issue, others say the 10 tooth will eat the ring gear. Engine is a 1969 - 1100S block with a Mk3 Cooper head. Not sure on the ring gear teeth number though - 129/107?
PostPosted: Sat Jan 26, 2019 9:00 am
Both pinions work fine. But original was 9 tooth.
PostPosted: Sat Jan 26, 2019 9:46 am
Many thanks Doc, was worried there for a bit :oops:
I wonder why some say the 10 tooth will eat the ring? :?:
Mick
PostPosted: Sat Jan 26, 2019 10:15 am
I have used a 10 tooth one for years.
Re the 127T ring gear that is for the Rover pre-engaged starter which has finer teeth.
PostPosted: Sat Jan 26, 2019 10:53 am
Interesting, thanks for the feedback.
Cheers :D
Mick
