It is currently Thu Jul 17, 2025 12:17 pm
 Post subject: Lockheed Master Pushrod
PostPosted: Wed Dec 26, 2018 10:12 am
I currently have my clutch system apart and want to replace the clevis pins ect.
I want to also replace the clutch master pushrod because I’m sure the holes in the fork are worn oval.
However I can’t seem to find them as a seperate part on any of the usual Mini Suppliers?
PostPosted: Wed Dec 26, 2018 10:53 am
Not seen them for years. Most people weld the pin holes and redrill. Even back in the 70s.
PostPosted: Wed Dec 26, 2018 11:22 am
In case it helps the BMC part number is 17H7557 and Lockheed 92021.
PostPosted: Wed Dec 26, 2018 11:46 am
A while ago I rang up AP Racing Australia as a Australian division of AP, they said they can still get a lot of the Lockheed brake stuff for minis.
It might be worth a look?
https://www.apracing.com/
Roads need more corners
PostPosted: Thu Dec 27, 2018 6:34 am
Hi Phillb
I have both types of clevis that have been welded. 1 for the tin can and for the plastic reservoir types. so if you get stuck let me know and you can have one.
Rob D
