It is currently Sun Jul 13, 2025 2:09 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Fri Dec 14, 2018 1:10 pm
There are a few articles here that may help.
https://www.minimania.com/Cooling__Cont ... ature_1506
https://www.minimania.com/COOLING___How_it_works_1009
https://www.minimania.com/LUBRICATION__ ... tical_1005
https://www.minimania.com/Oil_Coolers
PostPosted: Fri Dec 14, 2018 2:04 pm
Pullstarter wrote:
Harley wrote:
I have a 68 deluxe and a rover thermofan just bolted straight in without mods.
On the outer or inner side of the radiator?
Its fitted from in/under the front wheel arch. The rover shroud is shaped to clear any obstacles.
Its better than putting a fan straight on the radiator cause then it only cools the fins it touches and not the corners.
PostPosted: Fri Dec 14, 2018 2:22 pm
Harley wrote:
Would that be this one?
http://www.minispares.com/product/Class ... .aspx|Back to shop
PostPosted: Fri Dec 14, 2018 2:23 pm
gtogreen1969 wrote:
Thanks!
PostPosted: Fri Dec 14, 2018 2:33 pm
Pullstarter wrote:
No, I’ve used a factory one- looks nothing like that.
Ill see if i can take a pic.
PostPosted: Fri Dec 14, 2018 2:41 pm
Have you got a heater fitted, or any hose connected to the drivers side on top of the head? Does the heater blow hot?
PostPosted: Fri Dec 14, 2018 2:45 pm
Thanks, much appreciated :)
PostPosted: Fri Dec 14, 2018 2:46 pm
No, no heater in this one.
PostPosted: Sat Dec 15, 2018 6:23 am
The Rover one is a good design http://www.minispares.com/product/Class ... o%20search
It might be also worth checking belt tension and making sure it's not slipping.
PostPosted: Sat Dec 15, 2018 6:24 am
Thanks :) Belt tension and fan was checked when I did all the other work but cheers.
PostPosted: Sat Dec 15, 2018 6:34 am
Is the pump a large impeller one?
PostPosted: Sat Dec 15, 2018 6:39 am
Yep.
PostPosted: Sun Dec 23, 2018 9:55 pm
Has anyone used these? https://www.ebay.com.au/itm/50mm-Alloy- ... :rk:3:pf:0
They look too cheap to be any good.
PostPosted: Mon Dec 24, 2018 1:06 am
Good radiator, not sure about the fan... I used a 50mm one like that and it took a lot of work in modifying the fan shroud to move it closer to the engine and just squeeze it in with the shroud on the inner guard intact though. The 40mm ones are a much easier fit.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
Users browsing this forum: winabbey and 92 guests
