It is currently Mon Jun 30, 2025 5:29 pm
 Post subject: panels
PostPosted: Wed Jun 08, 2005 12:11 pm
mate the best way to do it is drill through the spot welds remove old panel with chisel and line up the panel with clamps before welding.
spot weld in the drilled holes as the new panel will not have holes and it will be close to factory finish.
remember to use dripcheck to seal the seams.
and use new clips (thats where the rust usually starts from) under the seam covers.
when you put the seam covers back on make sure you seal them with drip check also.
regards
opalmini
PostPosted: Wed Jun 08, 2005 12:42 pm
Some good points there opalmini, what is drip check and where do you get it from??
Steve.
 Post subject: drip check
PostPosted: Wed Jun 08, 2005 1:27 pm
it is what it is called you can get it from any automotve paint supplier its used for sealing panel joints like door skins to frames and it does not shrink dries hard and can be painted over.
PostPosted: Fri Jul 01, 2005 1:22 am
Which one of you arsehole moderators moved this topic to Mini Mods??? Im not trying to modify my mini, i'm trying to fix it. THATS why it was in Mini Chat.
Phuxake.
