It is currently Sun Jul 13, 2025 2:28 pm
PostPosted: Mon Oct 22, 2018 9:25 pm
I’ve always wondered what the correct orientation should be for the battery obviously negative towards the rear of the car. But are terminals closer to the spare tyre/centre of car or towards the drivers side?
PostPosted: Mon Oct 22, 2018 10:33 pm
Yeah so what I thought. This is for a LP038.
PostPosted: Tue Oct 23, 2018 10:09 am
What sort of battery is everyone running?
PostPosted: Tue Oct 23, 2018 10:10 am
a 520CCA Lion at the moment.
PostPosted: Tue Oct 23, 2018 10:12 am
Where are your battery terminals positioned Doc?
PostPosted: Tue Oct 23, 2018 10:13 am
I don't remember the number, but it's a V6 VT/VX Commodore battery from memory - the terminals are near the outside of the car.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Tue Oct 23, 2018 10:17 am
Towards the spare wheel. I don't like the terminals near the RH tank. :wink:
PostPosted: Tue Oct 23, 2018 10:24 am
Yeah I think ive been using a battery with the terminals in the wrong spot..... my terminals are closest to the spare wheel.
PostPosted: Tue Oct 23, 2018 10:29 am
That's safer IMO, even if not originality correct.
PostPosted: Tue Oct 23, 2018 10:47 am
Mine is a Century 58EB MF (560CCA). I would have swapped the terminal direction, but there wasn't enough length on the positive end to stretch it over
PostPosted: Tue Oct 23, 2018 10:57 am
Does the old battery cover still fit with the terminals on that side?
PostPosted: Tue Oct 23, 2018 10:58 am
I like that isolator idea.
PostPosted: Tue Oct 23, 2018 11:22 am
I'm not sure, I don't have the standard cover. Originally the battery was that direction with the terminals near the RHS tank
It's very easy to install too, just a short battery/earth strap and earth/earth strap. I made a new board to suit the twin tanks and isolator
PostPosted: Tue Oct 23, 2018 5:00 pm
See if I can get another 5yrs out of this one. Slightly larger capacity all round.
PostPosted: Tue Oct 23, 2018 5:38 pm
This is from "Anatomy of the Works Minis" (Brian Moylan):
