It is currently Sun Jul 13, 2025 6:58 pm
PostPosted: Mon Oct 01, 2018 9:16 pm
Hello from Spain, i'm looking for info about the rear seat belt mounting points and i found two threads about it
http://www.ausmini.com/forums/viewtopic.php?f=2&t=84411&hilit=seat+belt+rear+shelf
http://www.ausmini.com/forums/viewtopic.php?p=626757
but i couldn't see the images as they're in a photobucket server.
If someone could upload images of the reinforcements of the rear shelf I will be very grateful as I want to reinforce mine to install rear belts.
PostPosted: Mon Oct 01, 2018 10:28 pm
Here’s what I’ve done with mine. Reinforced with 3mm plate and made a 50mm high riser to sit the retractable seatbelt reels on. I will get it engineered when the car is on the road.
1972 Mk3 Mini 1000, 1150cc supercharged.
https://www.ausmini.com/forums/viewtopic.php?f=3&t=95872
PostPosted: Tue Oct 02, 2018 6:56 am
Do you know if you have local regulations in your country about seatbelt points?
Somerford mini in the UK do a weld in kit the same as the late UK cars
https://www.somerfordmini.co.uk/news-ev ... unting-kit
PostPosted: Tue Oct 02, 2018 7:54 am
Hello and thanks for the answers. In my country the later minis have the factory fitted plates similar to Someford kit.
The problem is that the installation requires welding to c-posts and my car is already painted so I'm looking for a solution similar to that adopted by Australian minis that does require welding in non sensible areas or a non welding approach (like hpal in previous post).
I have also seen the approach adopted by forum member Morbo28 in this post http://www.ausmini.com/forums/viewtopic.php?f=3&t=86822&start=795. Morbo28 comments that is guided by an engineer.
PostPosted: Tue Oct 02, 2018 9:46 am
No spreader plate is going to be much good when the panel it's attached to can't take the load... Factory cars with seatbelts mounted to the parcel shelf had a lot more reinforcement between the main panel and the body.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Thu Oct 04, 2018 5:55 pm
My thoughts exactly.. The red reinforcing plate shown above does nothing to distribute loads away from the parcel shelf.... and is a complete waste of weight and money...
Have look at the reinforcing plates that Leyland installed....
Cheers, Ian
PostPosted: Thu Oct 04, 2018 8:04 pm
I’ll let my engineer be the judge, if he’s happy then I’m happy.
Users browsing this forum: drmini in aust and 93 guests
