It is currently Sun Jul 20, 2025 1:59 am
 Post subject: Mk1 Aussie mini 1964.
PostPosted: Wed Sep 19, 2018 5:28 pm
Hi, need help with door rod inside door one end has long slot other end short slot what end fits on door opener on outside handle. Cheers Michael....
PostPosted: Wed Sep 19, 2018 11:09 pm
Doesn’t look like anything on my 1964 doors? Do you have wind up windows or the original sliding ones?
PostPosted: Thu Sep 20, 2018 3:29 pm
Tim,
That rod is used on windup window doors not sliding 850 ones.
PostPosted: Fri Sep 21, 2018 12:19 pm
Sorry for late response.....yes wind up window....any help out there what end to outside door handle cheers Michael.
PostPosted: Fri Sep 21, 2018 1:43 pm
These are handed L&R. The Miniking catalogue seems to show the longer slot to the rear.
My notes from when I did my doors, I have the LH link rod with offset at both ends towards the outside of the door - the centre section therefore closer to the inside of the car. Also the bar bends downwards at the front edge of the door.
PostPosted: Fri Sep 21, 2018 2:49 pm
As Bill B has suggested above, and with the longer slot to the outside handle mechanism
PostPosted: Thu Feb 07, 2019 6:31 pm
Thanks you for replys i appreciate the effort you went too.thanks again.michael
