It is currently Mon Jul 14, 2025 3:25 am
PostPosted: Thu Sep 13, 2018 10:33 am
Hi All,
I'm wondering if anyone has a general timeline for the Australian map pressed rocker covers, and were there any other types than these?
Cover 1: With curved breather - I'm guessing the earliest one?
Cover 2: Plain, no breather used with a PCV system?
Cover 3: Baffled breather (I have also seen the breather outlet facing the other direction) - from late cars with the breather going into the carb
PostPosted: Thu Sep 13, 2018 10:50 am
My March 69 Mini K had the rocker cover with the. Baffled breather and Australian embossing.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Thu Sep 13, 2018 10:59 am
Thanks Matt. That's a bit earlier than I first thought
This one is from an add for a 1970 K, the breather outlet is the opposite side of the baffle to my one above
PostPosted: Thu Sep 13, 2018 12:50 pm
Wow. :shock:
It's almost 11 years since I raised this topic for discussion. Some possibly inconclusive replies included.
viewtopic.php?f=2&t=37282
PostPosted: Thu Sep 13, 2018 5:21 pm
The 1969 Mini K brochure has the rocker cover venting to the passenger side.
The 1971 Clubman Van brochure has the rocker cover venting to the drivers side.
PostPosted: Fri Sep 14, 2018 9:57 am
My mid-1968 Deluxe has the passenger side venting "sausage".
PostPosted: Fri Sep 14, 2018 1:26 pm
A knowledgeable member has told me the embossed map on the 850 rocker cover came with the introduction of the 8Y prefixed engine in 1964.
The BMC Australia standard for this marking was introduced in July 1964.
PostPosted: Fri Sep 14, 2018 2:12 pm
Thanks Doug. I had been looking through lots of photos this morning and come to a similar conclusion. I guess it would have been fitted to the Morris 1100 as well, and the Cooper?
There is a change listed in John Sneddon's book in 1966, so possibly this is when they moved to the baffled cover. I will double check the part numbers when I get a chance.
My car had the rocker cover from the top photo when I got it. It's possible it's the factory cover given it had an 8Y engine factory fitted...
So updated estimate:
Type 1: 1964 to 1966
Type 2: 1967 onwards? Morris 1100S and GT
Type 3: 1966 till the imported engines started again. The baffle outlet side changed between 1969 and 1971
PostPosted: Tue Sep 18, 2018 9:50 am
And what do the letters in MOWOG stand for?
PostPosted: Tue Sep 18, 2018 10:55 am
It seems to depend on who you ask!
http://www.mossmotoring.com/mowog-mystery-solved/
http://www.gerardsgarage.com/Garage/Tech/MOWOG.htm
PostPosted: Tue Sep 18, 2018 3:03 pm
MOrris WOlseley Garages!
PostPosted: Tue Sep 18, 2018 5:15 pm
That's good information. It does allow for no mention of Austin and other marques.
