It is currently Sun Jul 13, 2025 10:18 am
 Post subject: Boot liner
PostPosted: Tue Sep 11, 2018 7:50 am
Hi, can anyone tell me if there was a boot liner made for a 1976 Mini if so where I may be able to get one. Thank you
 Post subject: Re: Boot liner
PostPosted: Tue Sep 11, 2018 10:44 am
If you have the bigger tank (7.5 gallons) then there is a pre made one available. It says it will also fit earlier cars with the smaller tank (I assume there will be a small gap on that side)
https://minikingdomonline.com.au/product/boot-liner/
Also flat ones:
http://minisport.com.au/mini-boot-board ... 5gal-tanks
http://minisport.com.au/mini-boot-board ... tank-minis
If you want a lining kit for the boot lid:
http://minisport.com.au/boot-lid-liner- ... o-cooper-s
You can also buy some plywood or similar from a hardware shop and cut them to size
PostPosted: Tue Sep 11, 2018 11:05 pm
Not sure when first arrived. but originally later model leyland minis were fitted with a boot mat that clipped to the boot lid and then lined your boot floor covering spare and battery.
PostPosted: Fri Oct 12, 2018 7:07 pm
I managed to source one of these second hand for my 74. Not sure what models had them and what didn't tho....
