It is currently Sat Jul 05, 2025 1:05 pm
Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Aug 27, 2018 8:01 pm
Goldbrocade_62 wrote:
simon k wrote:
yep - it's for the accelerator pedal - it stops the cable end of the pedal arm from going all the way to the floor when you don't have your foot on it.
It originally had a bit of leather over it to stop the pedal arm from going 'clink' when you take your foot off the pedal
Was it leather or proper non Chinese rubber
Looks like leather.
PostPosted: Tue Aug 28, 2018 7:25 am
This thread is perfect for a nidiot like me!
Does anyone know if the mk1 indicator stalk bulb can be picked up at jaycar or similar or is a special type of bulb?
Also my bonnet shuts this far. Well it shuts further then springs back to here.
I’ve tried screwing in the striker pin but it’s not budging!
Any thoughts for the day?
(Trying to get some simple wins to make me feel better, the tilting mini problem is making me sad)
PostPosted: Tue Aug 28, 2018 9:25 am
the bonnet is a long way forward as well... there are some 7/16 nuts at the back of the bonnet hinges, just loosen them a little bit (so they still 'grip' the bonnet, but you can slide the bonnet back and forth if you push) and push the bonnet back a bit
doing that might make it sit better
PostPosted: Tue Aug 28, 2018 4:05 pm
Is the interior light door switch on a 77 clubby connected via a bullet terminal or are the wires just soldered in?
Thanks muchly.
PostPosted: Tue Aug 28, 2018 8:35 pm
Thanks muchly.
should be a bullet - wiring looms aren't made to be installed permanently with soldering
PostPosted: Tue Aug 28, 2018 10:21 pm
Thanks Simon
PostPosted: Thu Aug 30, 2018 10:53 am
Thanks for identifying the part. But where does it attach to?.
PostPosted: Thu Aug 30, 2018 11:11 am
Silly question time :) Are there any low-back seats that will bolt directly (no mods needed) into a Clubman? Not a big fan of the high-back jobbies.
PostPosted: Thu Aug 30, 2018 11:17 am
Here is a pic
PostPosted: Thu Aug 30, 2018 11:19 am
It uses the right hand bolt that attaches the pedal box. In this photo the rubbing strip has shrunk and moved aside a little. When I touched it the black bit came off in my hand so I guess I'm going to need one of the MKO NOS parts posted earlier. The bit that came off appears to be rubber to me.
gtogreen beat me to it. :)
PostPosted: Thu Aug 30, 2018 2:26 pm
Seats fit the same in everything but the very last 1978 cars, but low back seats aren't legal to fit in something that came with high back seats.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Thu Aug 30, 2018 2:40 pm
Yes, if your adr plate has 22 or 22A stamped on it (1972 onwards) you must fit seats with head restraints.
Early seats had detachable restraints and were a bit less bulky than the later tombstone style. Some photos of them are in the interior trim section here:
https://classicregister.com/id-guides/h ... clubman-gt
PostPosted: Thu Aug 30, 2018 3:54 pm
Thanks for the info guys, much appreciated :)
PostPosted: Fri Aug 31, 2018 5:43 pm
Changed the oil filter on my 1098 today which is a work in progress, been running on and off for a few years. The oil was very thin in the filter and seemed to smell of fuel.... Can the oil be diluted at all from the fuel pump or something like that?? Thanks
PostPosted: Fri Aug 31, 2018 5:49 pm
Yes, if you have a mechanical fuel pump the diaphragm can split and leak petrol into the sump
Also if you filled the cylinders up with fuel it would make its way into the oil as well
