It is currently Fri Jul 18, 2025 12:03 pm
PostPosted: Sat Aug 25, 2018 4:20 pm
Hello All .
Has anyone got a good solution on how to fix the wear in the turn handle ?
Allen
PostPosted: Sat Aug 25, 2018 5:54 pm
Be the first and corner the market...
Some places sell springs and pins to service the locking lever, but I don't know how to remove the original pin. It doesn't drift through. It needs to be drilled out and I haven't found anyone who knows how to do this.
That should be a challenge for someone!
PostPosted: Sat Aug 25, 2018 8:02 pm
Bill B wrote:
... I don't know how to remove the original pin. It doesn't drift through.
It is a blind hole in the handle so you are right, it needs to be carefully drilled out. You can see a pic of a NOS pin here - https://minikingdomonline.com.au/produc ... andle-pin/
MKO has NOS of the complete quarter vent with handle for the passenger side only in case that's an option. Otherwise I'm not aware of a simple solution to fix a really wobbly one.
https://minikingdomonline.com.au/produc ... -mini-lhs/
PostPosted: Sat Aug 25, 2018 8:58 pm
I think everyone just replaces them with 2nd hand 1/4 windows.
PostPosted: Sat Aug 25, 2018 9:28 pm
I think you might be right. I considered this once.
I asked John (mini king) and Larry Howard (late) how to remove the pin and both acknowledged that neither had ever seen one drilled out, as the drill would drift into the softer merzak.
PostPosted: Sat Aug 25, 2018 10:01 pm
What about using a small milling cutter from the other side until it meets the pin, then punch the pin out?
Hardest part would be holding the damned handle in the mill with window attached..!!
PostPosted: Sat Aug 25, 2018 10:12 pm
Of course getting the pin out to remove the handle is one thing, but what do you do then?
I'm guessing it's the inside of the softer metal handle being worn away that makes the handle wobble, not the steel shaft on which it turns. Perhaps building up the shaft with some shim material, or drilling and lining the handle hole, otherwise I have no idea. :shock:
PostPosted: Sat Aug 25, 2018 10:35 pm
We need a solution for the future as we will run out of rh flipper windows. I will work on it.
Allen
PostPosted: Sat Aug 25, 2018 10:54 pm
I think I have worked out a solution, cut a slot in a suitable stainless steel washer and slide it under the handle where the gap is this will take out the wobble ,washer is held in with araldite ,where it locks araldite a small piece of 2mm stainless steel to the bearing surface to take out freeplay.
If done correctly it will not be obtrusive and it will look neat, you could araldite the stainless steel to the bearing surface of the handle when the handle is closed it cannot be seen. I will try this soon as I will be gold prospecting for a time in the bush if I find gold I will get someone else to do it.
Allen
PostPosted: Sun Aug 26, 2018 10:26 am
Guess your after a big nugget
PostPosted: Sun Aug 26, 2018 12:51 pm
p7676 wrote:
I will be gold prospecting for a time in the bush if I find gold I will get someone else to do it. Allen
Don't forget, "gold is where you find it".
Hope this helps :P
PostPosted: Sun Aug 26, 2018 3:32 pm
A few years ago, member on here did manage to get the catch off its pivot. I remember seeing a photo of the remains of the pivot, which then posed Winabbey's question of repairing the pivot and/or the catch.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 99 guests
