It is currently Tue Jul 15, 2025 4:24 pm
 Post subject: Dowty Fan
PostPosted: Tue Aug 21, 2018 10:41 am
Has anyone seen or got on of these fans? They were 4 blade, variable pitch. Supposed to increase hp by marginal amount.
 Post subject: Re: Dowty Fan
PostPosted: Tue Aug 21, 2018 12:02 pm
Here’s one for the engineers- if it increases power (presumably measured at wheels) does that mean its not cooling the engine as well as the original fan would?
PostPosted: Tue Aug 21, 2018 12:13 pm
The Dowty sucked less power at higher RPM as it reduced the angle of the fan blades.
From:http://mk1-performance-conversions.co.uk/a_light_read.html
I wonder if any newer clutch style fans would be compatible with the mini?
PostPosted: Tue Aug 21, 2018 12:20 pm
yes, but at speed the fan gets in the way of airflow through the radiator - fan is only effective at low speed or when stopped
PostPosted: Tue Aug 21, 2018 6:18 pm
if it runs off the belt the same as other mech fans , i can't see it living up to measureable gains. IF you want to decrease power losses, then go electric - but have good coolant warning systems as well - pulley and fan old fashioned, quite effective and remarkably reliable - mostly good things unless you need to go for ultimate last percentage of power. - ( i think i saw something like 2-4 hp on an engine bigger than ours - but cant exactly recall. - just my take on wringing out horsepower
PostPosted: Tue Aug 21, 2018 7:32 pm
I had one on my first car, a hotted 1100 motor. From what I remember, it wasn't to great at idle, but always run cool at speed.
