It is currently Mon Jul 14, 2025 1:14 am
PostPosted: Mon Aug 06, 2018 4:11 pm
Hello All,
I had the engine gearbox and clutch reconditioned Motor sounds great but I cant get the clutch to work, With the hydraulics working the clutch pedal only goes in about half way. I disconnected the slave cylinder and put a lever on the clutch arm it did not move the ball on the arm is fine ,I have a new arm arriving tomorrow, I set the large nuts up as per workshop manual, and the return bolt .Anyone got any ideas ?I am hoping the clutch is ok inside, TY
Allen
PostPosted: Mon Aug 06, 2018 4:21 pm
Step 1. Remove the large bolts ... the ones on the end of the release bearing shuttle.. and see if things improve...
Cheers, Ian
PostPosted: Mon Aug 06, 2018 4:31 pm
Cheers, Ian
Should that read the 2 large nuts?
PostPosted: Mon Aug 06, 2018 6:40 pm
yep..those thingies
Sorry
Step 2. Peel back the rubber cover on the slave cylinder. Have attractive assistant press clutch pedal as far as it will go. Check that the slave piston is not running up against the C-clip retainer at the outer end of the cylinder bore with the pedal as far down as it will go..... (no need to force it).
Cheers, Ian
PostPosted: Mon Aug 06, 2018 8:13 pm
when I used a length of square tube on the clutch arm it would not move in, would an attractive assistant fix it ? This would be a problem for me as I am bald and pretty ugly,
Allen
PostPosted: Mon Aug 06, 2018 10:34 pm
you didn't put the clutch plate in back-to-front did you?
if you can't move the arm with a bar, then the spring plate is hard up against something, take the wok off and have a look
PostPosted: Mon Aug 06, 2018 10:40 pm
So you are saying that when you push the pedal the arm doesn’t move at all???
If you installed new clutch straps are you sure you put them on the right way round?? There are two options and the wrong one will lock the clutch solid....
Cheers, Ian
PostPosted: Tue Aug 07, 2018 9:08 am
ok thanks it was fitted by an old BMC mechanic not me
PostPosted: Tue Aug 07, 2018 1:26 pm
sounds like a warranty job then...
PostPosted: Wed Aug 08, 2018 5:47 pm
Problem fixed I fitted a new lever arm ,anyhow it is fine now. Old arm looked ok
