It is currently Mon Jul 14, 2025 4:35 pm
PostPosted: Mon Aug 06, 2018 10:09 pm
Hi guys, got a weird one, that my local mechanic has his head scratching..
When braking the car veers ( very slightly to the left), we have checked the brakes ( minisport 4 pot alloy 7.5") , pads, bleed the fluid (new stuff) aligned the car, checked the steering rack... Any ideas.
being Hydro the left rides a few mm higher then the right ( when Im in it)
The handling is spot on and is amazing best its ever been..
when I fitted the brakes they had to cut down the original brake pads on them perhaps I have have a tad more brake pad on one side perhaps
Cheers Brett
PostPosted: Tue Aug 07, 2018 1:19 am
It's called drifting mate :-)
I live with fear everyday. but sometimes she lets me race.
PostPosted: Tue Aug 07, 2018 7:47 am
Cutting the backing of the brakes pads wont matter. Its only for clearance and none of the pad surface is touched (that I've ever seen).
Has it only just started, if so what have you altered lately?
Are the rear brakes adjusted correctly and the same?
Castor bushes ok?
How old are the flexible brake hoses?
Are the steering arms on the hubs tight?
Tyre pressures the same?
Just my first thoughts! Good luck
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Tue Aug 07, 2018 7:51 am
And is the pedal solid? Could be air in the rh caliper.
5/72 Clubman Gt
PostPosted: Tue Aug 07, 2018 8:29 am
or a sticky/binding piston(s)...
[PS pulling to one side is no joke...because in the wet it can really catch you out and maybe throw you off the road...]
PostPosted: Tue Aug 07, 2018 8:49 am
unfortunately the mechanic and myself have checked all the suggestions.... we even found the steering rack was loose....
PostPosted: Tue Aug 07, 2018 10:27 am
Steering arm bolts, in the top of the hub? I've had one let go before
PostPosted: Tue Aug 07, 2018 10:40 am
Steering arm dowels loose in the swivel hubs or arms? New bolts alone don't fix this. They need to be a TIGHT fit.
PostPosted: Tue Aug 07, 2018 1:18 pm
I had a similar experience with my previous Mk2 S and it turned out to be a worn upper arm pivot shaft and bearing. Could not detect it when hydro pumped up and loaded but that was the problem
Rod
PostPosted: Tue Aug 07, 2018 3:47 pm
Consider flexible brake hoses u/s. Or even steering rack bush worn.
PostPosted: Wed Aug 08, 2018 2:04 pm
Brett,
Try putting the rear tyres on the front and front on rear.
Tyres may be the problem :)
PostPosted: Wed Aug 08, 2018 9:41 pm
Are the rear slave cylinders the same inside diameter?
