It is currently Mon Jul 14, 2025 2:26 pm
PostPosted: Fri Aug 03, 2018 11:04 am
Hi dudes,
See in the attached pictures the replaces tie rod end rubber. It has a torsion spring around the bottom. There is nothing sealing it at the top though. Does there need to be wire around the top of the rubber to keep it sealed?
Bman
Zulu...
1967 mini Cooper S
PostPosted: Fri Aug 03, 2018 2:41 pm
nup, the rubber is pushed down the taper and the neck seals itself when you install them.
PostPosted: Fri Aug 03, 2018 9:27 pm
^^ What he said :)
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri Aug 03, 2018 11:58 pm
Gentlemen,
Many thanks.
Regards,
Z
Zulu...
1967 mini Cooper S
Users browsing this forum: drmini in aust and 83 guests
