It is currently Mon Jul 14, 2025 2:22 pm
PostPosted: Thu Jul 26, 2018 5:34 pm
Hello All
Anyone know what the oil pressure should be ,also the reading on the temp gauge is low the arrow only moves about 7mm.New motor has been fitted ,fully reco
Allen
PostPosted: Thu Jul 26, 2018 8:48 pm
The maximum oil pressure should be 75psi before the relief valve lifts off its seat.
The temp gauge is a long story, some listed here.
There are at least 2 different senders(GTR101 and GTR104) with different resistances that give lower/higher temp readings at the gauge. I'm in the middle of sorting this too.
There are others here who know a lot more about this.
PostPosted: Fri Jul 27, 2018 8:00 am
Does your fuel gauge read low as well , common problem is the voltage stabiliser not working properly .
