It is currently Tue Jul 15, 2025 1:58 am
 Post subject: Pot joint adapters
PostPosted: Sun Jul 22, 2018 9:04 am
Hi guys,
I just saw these adapters on MED's site. You can use your pot joint outputs and run the hardy spicer drive shafts. 8)
Has anyone used them?
http://www.med-engineering.co.uk/produc ... r-adaptors
Cheers :D
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
 Post subject: Re: Pot joint adapters
PostPosted: Sun Jul 22, 2018 9:47 am
And for those that don't know, Hardy Spicer joints fit fine on 850/998/1098 Mini rubber joint driveshafts. I run a pair since damaging an S one where the wire circlip sits.
PostPosted: Sun Jul 22, 2018 12:04 pm
I have slotted them in, and although only short term they were fine. ( my road motor with pot joints did a short stint in the sprints car ( hardy spicer). Literally plonk them on and away we went, and must of come off easily as well as i cant recall it, but the motor is sitting on a bench without the adpaters now. As i was doing an engine swap i cant tell you whether there would be any hassles doing in situ, but i would guess pop the top ball joints and plenty of swinging room
PostPosted: Sun Jul 22, 2018 9:17 pm
I ditched the hardy spicers in favour of pot joints...
PostPosted: Sun Jul 22, 2018 9:47 pm
Back in the 60s? There were similar ones here that fitted the old rubber joint diffs. I bought a 3 synchro box once that had a pair on. Don't know who made them, maybe were local?
PostPosted: Mon Jul 23, 2018 6:06 pm
Yes Kev I got a second hand set out of a mini K at the local wreckers Pretty sure Quinton Hazel.
Was late 70s
I was breaking the rubber ones at an alarming rate but these were awesome.
PostPosted: Mon Jul 23, 2018 6:44 pm
@ Ian_B
Not Quinton Hazel ones that fit into the rubber couplings, I have used those.
These ones looked like the flanges in the MED link above except they had a nut inside to hold them on the 850/998 diff output shaft.
Used with Cooper S Hardy Spicer uni joint assembly.
PostPosted: Mon Jul 23, 2018 7:30 pm
Back in the 60s? ,,,,,, maybe were local?
When Australia actually made stuff :!: :(
Users browsing this forum: Bing [Bot] and 100 guests
