It is currently Mon Jul 14, 2025 2:34 pm
PostPosted: Sun Jul 15, 2018 1:55 pm
What a fun job fitting these 2 trims ,seems to me they are not made correctly. I had to cut the trim where it fits under the binnacle and remove some board ,and I also had to cut where it fits next to the door seal. Anyhow they fit good now 3 hour job. Anyone had the same problem ?Tomorrow I am fitting the head lining I have fitted them in the past.
Allen
PostPosted: Sun Jul 15, 2018 2:20 pm
Did you get the correct ones? The Mark 1 and 2 trims are different.
PostPosted: Sun Jul 15, 2018 5:18 pm
MK said they were the ones
PostPosted: Sun Jul 15, 2018 6:02 pm
the trim fits ok around the binnacle curve ,the ends are not correct that is why I had to modify them
Allen
PostPosted: Sun Jul 15, 2018 8:32 pm
I can't explain or help with the problems you are having, but I completely sympathise. In the past I have made my own backboards and it is easy to make them slightly too big and stuggled to fit them into the curve of the dash. Recently bought a set of Mk2 boards for my mini K and covered them with my own vinyl and they fitted really easily at both ends!! Was very happy.
PostPosted: Mon Jul 16, 2018 7:36 pm
I struggled too, mine has clubby vents so double painful.
Sent from my SM-G950F using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
PostPosted: Mon Jul 16, 2018 10:42 pm
What is the best product (the board material) used to make these and door cards etc?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Tue Jul 17, 2018 6:12 pm
Doing the same job on mine at the moment. Initially bought 3.2mm Masonite from Bunnings, but not enough flex to fit. Today I am buying 2.5mm modelling ply. Will see how that works.
PostPosted: Wed Jul 18, 2018 10:55 am
It works perfectly.
PostPosted: Wed Jul 18, 2018 11:00 am
A local auto trimmer may sell you the cardboardy stuff they use.
PostPosted: Wed Jul 18, 2018 12:45 pm
From experience, I don't like your chances of that ever happening.
PostPosted: Wed Jul 18, 2018 6:29 pm
My mate's an upholsterer so he let me ring up and order some.....works well. Have enough for some cards if anyone close wants some......
Cooper S Mk2
Cooper S Mk1
PostPosted: Wed Jul 18, 2018 7:38 pm
Got mine from the local trimmer.
