It is currently Mon Jul 14, 2025 11:37 pm
 Post subject: Alignment Specs
PostPosted: Mon Jun 25, 2018 3:31 pm
Hi guys,
Thinking of getting an alignment I have fully adjustable front and back.. what are people running?
Thanks
 Post subject: Re: Alignment Specs
PostPosted: Mon Jun 25, 2018 3:44 pm
brett wrote:
Hi guys,
Thanks
What tyres and what type of driving? Hard tyres with highway running is alot different to sticky tyres for weekend track days.
A good all round setting for 10" tyres is
Front
-1.5deg Camber
+3 deg Castor
1.6mm Toe Out
Rear
-0.5 Camber
1.6mm Toe In (0.8mm each side)
PostPosted: Mon Jun 25, 2018 4:30 pm
Running 10" Dunlop aquajets little bit lower than factory height.
PostPosted: Mon Jun 25, 2018 4:33 pm
Ok. Then I would not run as much front Camber. -0.5 to -1deg would be good.
PostPosted: Mon Jun 25, 2018 4:49 pm
Front
-1.5deg Camber
+3 deg Castor
1.6mm Toe Out
Rear
-0.5 Camber
This is pretty much exactly how my car is set up, works good for A008s - no experience with any other tyre other than worn out, 20 year old Bridgestones :shock:
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Mon Jun 25, 2018 8:59 pm
Front
-2° Camber
+6° Caster
1.5° Toe Out
Rear
-1° Camber
2° Toe Out
PostPosted: Tue Jun 26, 2018 7:52 pm
Front
-3° Camber
+0° Caster
2mm Toe Out
Rear
0° Camber
5° Toe Out (don't do this at home kids)
PostPosted: Tue Jun 26, 2018 8:51 pm
I’m jumping in on this!
What wheels do you have with those castor settings Aaron and Simon?
I’m trying to fit a set of 10 x 6 minator or GB’s to a mk1 without any luck.
PostPosted: Wed Jun 27, 2018 11:11 am
well Aaron doesn't have any caster, and I have heaps, so a bit of a difference - last event we were both on 12" yoko A539. My wheels are 12x5, I don't know what the offset is, but not huge, they sit more-or-less flush with the flares
Mine rub on the leading edge of the guards at about 1/2 lock, I stretched one side a bit to get some more clearance but it still touches. I'm going to have the wheels machined to remove some offset, they have a lot of meat that can be removed without any rigidity issues. No problem with clearance on standard 10" Cooper S steel wheels. I also run my hydro with 300psi, so the car sits tall which helps with clearance
No doubt your minators have massive offset - that extra 1" of width would be mostly outside the normal wheel centreline.
here are a couple of pictures that tell the story (apologies for the orientation - consider it neck exercise)
PostPosted: Wed Jun 27, 2018 11:23 am
Love the colour! I'd perhaps pump up the suspension..
PostPosted: Wed Jun 27, 2018 12:34 pm
simon k wrote:
Front
-2° Camber
+6° Caster
1.5° Toe Out
Rear
-1° Camber
2° Toe Out
... and a dirty big rear swaybar :lol:
Mine's only just been finished and barely driven on the road yet, so I envisage this will change
Front
-2.5° Camber
+5° Caster
1/8" toe out
Rear
-0.5° Camber
zero (parallel) rear toe
PostPosted: Wed Jun 27, 2018 12:38 pm
it is all the way up... 300psi... it's just that a lot of caster puts the wheel a long way forward when turning
and yes Stuwey, a dirty great big rear swaybar :)
PostPosted: Wed Jun 27, 2018 8:32 pm
It's an easy fix, take bolts out at front of subframe and fit the appropriate number of mudgaurd washers between frame and body panel.
PostPosted: Wed Jun 27, 2018 10:32 pm
now there's a good idea - I'll have a squiz - thanks!
PostPosted: Thu Jun 28, 2018 2:15 pm
aaron wrote:
Front
-3° Camber
+0° Caster
2mm Toe Out
Rear
0° Camber
I'm struggling to work out the advantage to 0 degrees of caster? I get that from the 5 degrees toe out at the rear you might race or like it loose and the caster might help there, lower steering effort if you had mahoosive or sticky tyres? Jacking reasons related to castor? But are they that significant?
Roads need more corners
