It is currently Tue Jul 15, 2025 2:00 am
 Post subject: twin carbies 1970 cs
PostPosted: Tue Jun 19, 2018 10:01 pm
Fitting the carbies to the manifold. is it best to fit them to the heat shield then to the manifold as a pair ?
Allen
 Post subject: Re: twin carbies 1970 cs
PostPosted: Wed Jun 20, 2018 7:46 am
Manifold on, heat shield on then fit carbs last.
1962 Mini Speed sports sedan
PostPosted: Wed Jun 20, 2018 5:11 pm
As above. I always place the linkages between and pick up both at once and then holding it all together with the linkages staying in place place it on the manifold.
PostPosted: Wed Jun 20, 2018 5:31 pm
and then you bump one of the carbs against a stud and it moves out of alignment and then drop them both...
I used to do something similar, now I just have one carb, much easier to deal with!
Users browsing this forum: Bing [Bot] and 92 guests
