It is currently Mon Jul 14, 2025 9:43 pm
PostPosted: Wed May 30, 2018 5:16 pm
Hello All ,
Is 2mm enough clearance between the oil cooler and the starter motor ?
Allen
PostPosted: Wed May 30, 2018 7:11 pm
with a solid mounted power unit it is but with rubber mounts that will degrade soon after fitting no.
PostPosted: Wed May 30, 2018 8:18 pm
Place it in gear and rock it back and forth to check the clearance. My oil cooler has about a 5mm gap between the starter motor and about a 2mm between the grill.
PostPosted: Thu May 31, 2018 7:16 pm
No that is not enough Gap. You need one of my Bosch Planetary geared starters. They are more Slimline. Besides much more powerful.
"Let us remove your "SHORTS"
PostPosted: Thu May 31, 2018 7:31 pm
I wouldnt use a gemini one on a cooper s but i bought one today for 50 bucks Original non China.
My Cooper S has Lucas original and oil cooler and it all fits
Is Bosch still who they once were or are they just a name now?
