It is currently Tue Jul 15, 2025 12:54 pm
 Post subject: heater core 1970 C.S
PostPosted: Tue Apr 10, 2018 4:50 pm
Hello All,
I am having trouble finding a new core or a good second hand one. Does anyone know where I can get a core.
TY Allen
 Post subject: Re: heater core 1970 C.S
PostPosted: Tue Apr 10, 2018 4:54 pm
This one?
https://minikingdomonline.com.au/produc ... r-s-mk1-2/
http://minisport.com.au/mini-cooper-s-heater-core
PostPosted: Tue Apr 10, 2018 5:17 pm
timmy201 wrote:
"and just requires inlet/ outlet tubes to be moved so it can be easily fitted."?
PostPosted: Tue Apr 10, 2018 5:41 pm
While awaiting other responses I suggest you do a search on heater core or similar.
I did and found this post where the owner replaced the core. Try a PM to him to see where he got it.
viewtopic.php?f=3&t=95728&p=1023097
PostPosted: Tue Apr 10, 2018 9:22 pm
Doug you are right, I did replace mine. The ones shown in the link fit our housings. I think the note about moving the inlet pipes refers to the Moke application only.
Mat
1970 Mk2 Cooper S
PostPosted: Wed Apr 11, 2018 5:35 am
Have you tried John at MKO
PostPosted: Wed Apr 11, 2018 2:08 pm
I’m on the middle of having mine re cored and having a right angle put on the pipes, do you have the old one that can be repaired??
PostPosted: Wed Apr 11, 2018 2:09 pm
PostPosted: Wed Apr 11, 2018 2:32 pm
Incase your picture throws anyone. Its from a Beehive heater late 1970.
PostPosted: Wed Apr 11, 2018 8:37 pm
Yep I removed the tanks and the core is RS to fit a new core will cost $350.New one from John S $190. The radiator shop told me they cannot compete with the cost of new heater units .
PostPosted: Thu Apr 12, 2018 10:28 pm
Mine was slightly cheaper but I had the inlet pipes moved too. I also questioned it. Expensive for such a small core. I couldn't see the correct one for my car. Bit the bullet and had it done. Haven't picked it up yet so I hope they did a good job. Have had radiators done by them before and turned out pretty good.
