It is currently Tue Jul 15, 2025 10:30 am
 Post subject: 29d dizzy
PostPosted: Sun Apr 08, 2018 7:51 pm
can any please tell me what this dizzy is from
Sent from my SM-J530Y using Tapatalk
 Post subject: Re: 29d dizzy
PostPosted: Sun Apr 08, 2018 8:03 pm
Clubman GT.
PostPosted: Sun Apr 08, 2018 8:05 pm
winabbey wrote:
Clubman GT.
thanks are they the same from a oz cooper s
PostPosted: Sun Apr 08, 2018 8:14 pm
kiwiinwgtn wrote:
winabbey wrote:
Clubman GT.
Same as a MK2 S but it would have an earlier date like this one and an A instead of B.
Here are the specs
PostPosted: Sun Apr 08, 2018 8:18 pm
gtogreen1969 wrote:
kiwiinwgtn wrote:
winabbey wrote:
Clubman GT.
Same as a MK2 S but it would have an earlier date like this one.
Here are the specs
thank you just what i wanted to know.
on a side question are the base plates fixed since it dosnt have vacuum advance
PostPosted: Sun Apr 08, 2018 8:19 pm
They have a fixed points plate and a 15 deg mechanical advance plate underneath.
PostPosted: Sun Apr 08, 2018 8:24 pm
Here is another 62941090A dated 11/68.
PostPosted: Sun Apr 08, 2018 8:58 pm
If you want to sell it, this would be perfect for GuamMini's 1973 Australian GT. He was after one a while ago.
1970 MK II Cooper 'S' Supercharged 1310 with Megajolt.
1970 MK II Cooper 'S' Original resto project (SOLD)
1962 850 Original. (Under restoration)
1973 Leyland S (My first car. Now rebuilt, so my kids can learn how to drive a real car).
VMCI # 215.
PostPosted: Sun Apr 08, 2018 10:49 pm
next question: Is there a timing light peoples use to check those advance readings at the respective rpms? Thanks.
PostPosted: Sun Apr 08, 2018 11:01 pm
I use an Innova dial back timing light and take a reading every 1000rpm to plot a curve.
Similar to this one. https://www.ebay.com.au/itm/Innova-Digi ... Swkh9acC7F
PostPosted: Mon Apr 09, 2018 10:30 am
Yep, I have the same Innova and find it very easy to use. You just need a clearly labelled TDC marker and you can work out the rest using the dialback feature.
You can also take to an old school auto electrician and they can spin it up on the bench dizzy tester.
PostPosted: Mon Apr 09, 2018 12:10 pm
Thanks guys. That easily answers the usual question "what do you want for your birthday?"
PostPosted: Mon Apr 09, 2018 12:12 pm
Or you can just borrow mine ;)
Cheers, Ian
PostPosted: Mon Apr 09, 2018 12:24 pm
Cool, thanks mate!
