It is currently Tue Jul 15, 2025 5:29 pm
PostPosted: Fri Mar 30, 2018 7:33 pm
So my question is are the rear quarter vent latches adjustable? My quarter vents stay open until about 80kph then close with airflow. At about 110kph they flap like crazy unless latched closed which defeats the concept of flow thru ventilation.
Before I butcher the two fittings above and below the hinge pin, does anyone know whether they are threaded and adjustable?
All suggestions appreciated.............maybe an aluminium plate and zip ties to hold it over centre??
1970 Mk2
1968 Mk1 project
PostPosted: Sat Mar 31, 2018 9:46 am
Ring Warner or Smith they may have some sand paper to rough up the hinge.
PostPosted: Sat Mar 31, 2018 10:07 am
Thanks for the suggestion, I was trying to avoid "Hinge Tampering", you just never know who's watching.
1970 Mk2
1968 Mk1 project
PostPosted: Sat Mar 31, 2018 10:19 am
Mozzie I have a mk 2 1970 april build the window was a common problem tighten the rivets use small hammer and DOLLY not the Parton type.
Allen
PostPosted: Sat Mar 31, 2018 5:49 pm
I find they stay open if you fit new Oz rubbers. Mine have been fine for 10 years now.
To adjust tightness when closed I used flat washers under the latch.
