It is currently Tue Jul 15, 2025 11:54 am
PostPosted: Thu Mar 22, 2018 6:01 pm
I can't find my workshop manual. Can anyone tell me what the minimum thickness is for a brake drum for the rear of the mini?
PostPosted: Thu Mar 22, 2018 6:06 pm
The new pair I picked up yesterday have 'MAX DIA 179.3MM' cast in to them, which is 7.060", or 60 thou over standard.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Thu Mar 22, 2018 9:51 pm
Thanks. I'll measure some that I have at home before getting new ones.
PostPosted: Mon Mar 26, 2018 1:58 pm
I wouldn't bother ****ing around with measuring brakes shoes id just go new all the time no question asked
Messing around with old brakes parts is like playing Russian roulette i wouldn't do it for around $25 or so a set new
PostPosted: Mon Mar 26, 2018 3:46 pm
Plus 1.
PostPosted: Mon Mar 26, 2018 5:01 pm
guys I think you are misunderstanding what is being asked here, they are discussing the "service limit" on the drums themselves, not the shoes
seems a bit arbitrarily to throw out the drums each time you change shoes, doesn't it?
I have a car here I just removed the drums and binned them and they were over 50 years old, according to the dates on them.
PostPosted: Mon Mar 26, 2018 5:37 pm
I thought the question was answered by Matt I on the very first reply.
PostPosted: Mon Mar 26, 2018 6:06 pm
I understand standard what the question is about but bare in mind when skimmed you should you over size brake shoes to compensate for drum machining
PostPosted: Mon Mar 26, 2018 6:17 pm
I replaced mine as all the spacer drums I had were either machined oversize or warped, and oversize linings to match the drums were twice the price of new standard ones... I agree that replacing everything generally makes more sense now based on the cost compared with machining and linings to suit.
*witty signature*
