It is currently Thu Jul 17, 2025 1:14 am
 Post subject: Borrow Flywheel Puller
PostPosted: Fri Jan 19, 2018 10:10 pm
I'm located at Brandy Hill NSW and looking to borrow a flywheel puller.
If anyone close by is willing to assist please let me know.
PostPosted: Sat Jan 20, 2018 9:56 am
A bit of 1/2'' plate and some 3/8'' threaded rod, make your own. That way it'll guarantee you that nothing will go wrong with clutch etc.........you're prepared for it. ( Murphys law number 27.5)
PostPosted: Sat Jan 20, 2018 11:27 am
Make sure you have something to fit into the crank bolt hole to protect the threads if you use a centre bolt!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sun Jan 21, 2018 10:48 am
Take the keyway out and put the bolt back in. don't do it all the way up.
PostPosted: Sun Jan 21, 2018 4:06 pm
You're referring to the key, aren't you. Not the keyway.
Users browsing this forum: 70K1100 and 84 guests
