It is currently Tue Jul 15, 2025 12:15 pm
PostPosted: Fri Jan 19, 2018 12:05 pm
Looks like one of the alloy bodied aftermarket units sold a few years ago as a Mk I booster replacement. Spares (UK) will sell you a new replica Mk I unit with an iron body...
Or, just pull your unit apart and clean it out. If you do it methodically you shouldn't have any trouble putting it back together. It would be interesting to know how (if at all) different they are internally from the original item. They're not very complicated. The "Black" Leyland manual gives a good run down on the refurbishment of the original type.
Could also be a sticking master cylinder or caliper piston...
Running without the booster is certainly a realistic way of checking whether its your problem.
The bracket is not correct for your type of booster but may be proper for a Mk II/GT (but either way shouldn't have an effect on its operation).
Cheers, Ian
PostPosted: Fri Jan 19, 2018 12:41 pm
Your bracket is the correct stock one for the Australian PBR VH44J booster.
It has been bent to clear the Lockheed copy booster and it's facing the wrong way.
PostPosted: Fri Jan 19, 2018 2:40 pm
Do you have any brake or hydraulic places in Guam? Even an aircraft place?
UK boosters are different.
The correct booster is a PBR VH44J.
You can buy a new Chinese copy of a VH44 on ebay but it won't have the same amount of assistance as the VH44J.
This should be the right one, 5/8 bore, High Pressure...
https://www.ebay.com.au/itm/VH44J-GENUI ... SwG-1Wuv9M
PostPosted: Fri Jan 19, 2018 3:09 pm
the one pictured in that ebay add has the
vacuum diaphragm 180 deg out
mounting bolts on the wrong side for a mini
PostPosted: Fri Jan 19, 2018 4:42 pm
They should be able to changed to how they should be by opening up vac part undo the bolts and turn it 180
PostPosted: Fri Jan 19, 2018 7:20 pm
What dont you know about bricks haha
PostPosted: Sat Jan 20, 2018 9:55 am
The original brake booster for the Australian Clubman GT was a PBR VH44JA. The later MK2 S used the same booster.
IIRC the A signifies it is a RHS mounting.
The body and vacuum chambers can be rotated and aligned to suit either LHS or RHS mounting.
68 build Mk1 Cooper S
PostPosted: Tue Jan 23, 2018 12:42 pm
Related hijack...
Who reconditions VH 44j boosters now?
I have an old one complete for my son's car but it needs a full recondition job.
I know hydroboost used to.
PostPosted: Tue Jan 23, 2018 1:47 pm
Related hijack...
Just sayin' Doc...for the price of a new one, why even try? Originality? safety first?
This is from someone who tried to get a Girling Booster repaired fairly recently for a non-Mini by two VERY well respected shops...both failed miserably...so I bought a NEW VH40 (9").
PM sent about Hydroboost...
PostPosted: Tue Jan 23, 2018 2:00 pm
Related hijack...
You can get VH44 reco kits from the usual Mini parts suspects should you want to do it yourself. Surely a reputable brake repair place could do it, if you supplied or pointed them to a source of supply of the kit.
PostPosted: Tue Jan 23, 2018 2:29 pm
I got mine done by B&R Brakes 15 years ago, but it was cheaper recently to get Hydroboost to do them exchange. I will get B&R to quote first.
PostPosted: Wed Jan 24, 2018 6:32 am
So where did Hydroboost go? , i brought a 44J off them about 2 yrs ago ,found Terry to be a great bloke to deal with .
PostPosted: Wed Jan 24, 2018 8:01 am
I got a quote from Terry, $225 exchange or fix mine, or $325 outright. :)
PostPosted: Wed Jan 24, 2018 9:48 am
How recent, Doc? I also heard the story he had shut up shop.
PostPosted: Wed Jan 24, 2018 10:58 am
Today. He is now in Echuca.
Users browsing this forum: Bing [Bot] and 101 guests
