It is currently Thu Jul 17, 2025 1:29 pm
PostPosted: Mon Jan 08, 2018 7:46 am
Hi all,
Been a while since i posted here!
I've got an issue with my car at the moment and was wondering if it was something simple that i'm missing or if my alternator is stuffed.
I replaced the alternator a couple of months ago with a new 45amp unit (the one Mini Kingdom Online sells) and it was working fine for a little while but then the charge light just stopped coming on before starting the car.
I've removed the charge light wire from the terminal on the alternator and earthed it to the body and it lights up fine when the ignition is set to the on position, so i know the wiring / bulb are ok. I've tried earting the body of the alternator to the same point on the body, still no go. Is there anything else i can check or is it just a case of need another new alternator?
PostPosted: Mon Jan 08, 2018 8:44 am
Is it charging the battery when running? (13.8-14.2 V, I think?)
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Mon Jan 08, 2018 9:28 am
Which terminal on the alternator have you connected the sensing wire to? If it's connected to the charge circuit the light won't come on.
PostPosted: Mon Jan 08, 2018 11:22 am
Sorry should have clarified... battery not charging (no voltage change when engine running) and there is only one way it can be connected - small connector on the IGN terminal and 2 x big connectors to the solenoid (same connector, just has 2 posts)
Sent from my SM-G930F using Tapatalk
PostPosted: Mon Jan 08, 2018 11:26 am
This is the type of connector my alternator has
PostPosted: Mon Jan 08, 2018 11:58 am
Does sound like it’s failed unfortunately.. see if you can get an auto electrician to spin it up and test it or send it back?
PostPosted: Mon Jan 08, 2018 12:34 pm
Yeah that's what I suspected. My car seems to keep killing them. Could it be high rpm that is killing them, or not related?
PostPosted: Mon Jan 08, 2018 2:45 pm
The Mini King
Hi Chux,
I hope you understand that if there is a problem with anything!! I sell to you, or anyone else
If there is a genuine problem with what I have sold, I am happy to Repair Re place or refund .
I do want all my transactions to be fair to both sides, and I am happy to listen to anyone who
wants to talk to me about any problem they have, be it with my products myself or any other issue.
I do not always get it right but as I am getting older and I know my chances of making mistakes
have increased over the years. However I believe I always treat people in a fair manner
John Smidt
Chux wrote:
Hi all,
PostPosted: Mon Jan 08, 2018 3:19 pm
John Smidt wrote:
Hi Chux,
John Smidt
Chux wrote:
Hi all,
Hi John,
Apologies if this post came across as though I was looking for justification to get a replacement part from you, my intentions were in fact the complete opposite.
I wanted to make sure that I'd checked everything I could at my end and to be as sure as i could be that the problem was indeed a failed unit before I even contacted you. Parts fail sometimes and that's fine but I didn't want to ask for a replacement unit only to fit it up and still have the same issue. That's not fair for you to wear the cost of replacing a part that hasn't actually failed!
You've always looked after my dad (Terry with the moke) and I, replacing parts no questions asked and offering great advice whenever needed.
Once again, apologies if this post came across the wrong way.
PostPosted: Mon Jan 08, 2018 5:02 pm
Chux - pretty sure that wasn't what John meant so I don't think there's a need to apologise. I mentioned your problem to him today so that's probably the reason for his post, to simply ensure you know he will fix it if it turns out to be the alternator.
PostPosted: Mon Jan 08, 2018 7:30 pm
The Mini King
Hi Chux,
No Mate I was not offended in any way, I know you and your Dad,
and you are both fair minded honest People. As winnabey has explained I just wanted to
reassure you,
John Smidt
PostPosted: Tue Jan 09, 2018 6:45 am
Oh dear, worry, worry...
Hi Chux
About time you got a bigger pulley to slow the alternator down or lower the revs by 2000 :shock: or you'll just keep bustin them :cry:
Graham Russell
PostPosted: Tue Jan 09, 2018 8:49 am
Chux wrote:
How many revs are we talking?
PostPosted: Tue Jan 09, 2018 8:54 am
John Smidt wrote:
Hi Chux,
reassure you,
John Smidt
Cheers John :)
PostPosted: Tue Jan 09, 2018 8:57 am
GR wrote:
Hi Chux
Graham Russell
Cheers GR, this is the sort of thing i was concerned about. I don't have a very heavy load on the electrical system (no stereo or anything like that) so a bigger pulley would be fine i think.
Users browsing this forum: No registered users and 65 guests
