It is currently Mon Jul 21, 2025 6:04 am
 Post subject: 998/1100 Head Gasket
PostPosted: Thu Apr 16, 2015 4:52 pm
I have a 998 that is +120tho that doesw a head gasket once a year ( right when it gets dragged out of the shed before hay ) .. is there a MLS cometic type gasket for the beloved small bore ?
Or Can i use a 1275 gasket BK450 or Cometic type ...
Head is a 12g295, and has been skimmed to check that its flat ..
any help would be Great
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
 Post subject: Re: 998/1100 Head Gasket
PostPosted: Thu Apr 16, 2015 7:49 pm
http://russellengineering.com.au/project-68mm-part-1/
+120 is pretty sizeable, and not far off the 68mm at +13x so I would suggest you are starting to run into gasket overlap on the cylinder and will need to go to a 1275 one. Have a read of the above to see what GR did to get round it.
Aaron
PostPosted: Thu Apr 16, 2015 8:41 pm
Give these guys a call - http://www.ridgecrest.com.au, they will make you what you require.
Have a Nice Day.
PostPosted: Sun Dec 10, 2017 1:48 pm
Hi all! Anyone know of a supplier of MLS head gaskets for 998cc? (or perhaps would a 1275 be able to be fitted?)
Any info appreciated :)
PostPosted: Mon Dec 11, 2017 2:04 pm
I used a BK450 on a 68mm bore with a 202 head. I had to block off 1 water hole and move 2 others by plugging and re-drilling.
However back in 1968 I used a 1275 gasket and 12G940 head on a 68mm bore, no water hole problems. (Block was notched for exhaust valve clearance).
PostPosted: Mon Dec 11, 2017 2:51 pm
Doc! Back in 1968?! I was 6 years old and I've owned Mini's for 35 years! I bow to you Sir!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Mon Dec 11, 2017 4:37 pm
Got my first Mini in 1964. An 850 with twin hs2 carbs. After I rode in my mate's 850 and got hooked. :)
But in 1969 I had a 20 odd year love affair with Fiat 124 coupes. When Fiat pulled out of Oz and parts got unobtainium I said eff it and went back to Minis. :wink:
But my wife did own a MK 1 S and a Morris 1300 auto in that period.
Users browsing this forum: JM1275 and 95 guests
