It is currently Mon Jul 21, 2025 6:21 am
 Post subject: Re: Mini or Brick
PostPosted: Tue Nov 28, 2017 7:51 am
It is a pity some things just arent available in original form and yes that panel fits really well and the guy is doing a good job.I have seen some really shoddy work out of some modern panel shops.
PostPosted: Wed Nov 29, 2017 8:20 pm
The correct Mk1/2 front panels are still being manufactured and are available from a number of suppliers , Somerford Mini in UK have quite a range of body panels , as have a few Aussie suppliers as well :D
http://www.somerfordmini.co.uk/eshop/in ... &chapter=1
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Wed Nov 29, 2017 9:49 pm
if you look closely at the front panel the only difference is the number plate bracket, bonnet lock area same as original no hole for vent LH side. I have looked at the UK websites there is no front panel identical to an Australian model is you think there is please let me know. Mini kingdom agree.
PostPosted: Thu Nov 30, 2017 8:04 am
They may not be exactly the same , but pretty damn close , a lot closer match than the Heritage panels that most suppliers try to sell you .I bought a Mk1 apron panel from M-Machine a few years back and its pretty much identical to the original .
http://preview.m-machine.co.uk/CATALOGU ... alogue.pdf
1965 Morris 850
1977 Leyland LS
PostPosted: Thu Nov 30, 2017 8:20 am
There is 2 types of number plate mount brackets positions as there is 2 different lengths
PostPosted: Thu Nov 30, 2017 10:14 am
M ,machine have informed me there front panels are different than the Australian Minis and as far as they know the Australian front panels have not been available for a long time, you have to modify a UK panel
PostPosted: Thu Nov 30, 2017 6:19 pm
Well there you go then , end of story :D
1965 Morris 850
1977 Leyland LS
PostPosted: Thu Nov 30, 2017 6:53 pm
Good to be properly informed.I know my sills are wrong and dont care The rover sills are by far superior but not original.Do I care NO Would I rather patched old original sills waiting to break out again A big NO.If you are happy thats good but know what you are getting and thats a common problem nowadays .Beware of snake oil and chinese crap. :wink:Hence my clutch issue that wont happen thanks to the Doc
PostPosted: Thu Nov 30, 2017 7:02 pm
It is much better to be informed correctly and make your decision than ill in formed and do it wrong that is why we have these forums
