It is currently Fri Jul 18, 2025 2:02 pm
PostPosted: Sat Nov 11, 2017 4:41 pm
I am fitting the engine to the subframe out of the car, can I fit the carbies ? I am lifting the body over the engine and subframe, also are there any other problems which may arise ? Thanks
P7676
PostPosted: Sat Nov 11, 2017 4:51 pm
No you probably wont be able to fit the carbies. it is also much easier to drop the engine in from the top with the subframe already installed to the body.
PostPosted: Sat Nov 11, 2017 5:30 pm
I've fitted the engine and subframe as a unit a few times, don't have any trouble with it... but no, can't do it with the carbs fitted, they hang over the crossmember when installed.
PostPosted: Sun Nov 12, 2017 1:24 pm
I'm with JimL....
But be very careful with the exhaust manifold. Some ( including the original S manifold) can be almost impossible to fit once the engine is bolted into the subframe - whether or not the subframe is attached to the car...
Having been caught out, I tie the manifold roughly in place with some thin rope before dropping it into the subframe.
Cheers, Ian
Users browsing this forum: Bing [Bot] and 117 guests
