It is currently Sat Jul 19, 2025 8:33 pm
 Post subject: mini starter motor
PostPosted: Tue Oct 17, 2017 4:16 pm
1970 Mini starter motor. I have just fitted a new Bendix to the starter motor and I have noticed there is about 2mm end play in the starter motor shaft and a small amount of side play. Will this cause any problems ?
P7676
 Post subject: Re: mini starter motor
PostPosted: Tue Oct 17, 2017 8:38 pm
Wasn't there a fibre washer in drive end that used to smash and fall out, causes end play. Too much side movement may cause poor meshing and or possible overlapping/jambing.
PostPosted: Tue Oct 17, 2017 9:32 pm
New bronze bushes and brushes are still available from Karcraft, Minikingdomonline and others.
