It is currently Sat Jul 19, 2025 8:40 pm
PostPosted: Thu Oct 12, 2017 10:14 am
Hopefully a quick one for those that know / have a flange of each to compare:
Is the drive flange of an 8.4" brake setup the same in offset from bearing to wheel mounting face as it is on a 7.5" setup? Was looking at some photos recently and it looks different but i can't quite tell.
Thanks!
:D
PostPosted: Thu Oct 12, 2017 4:12 pm
they mount differently, one with the wheel studs, the other has own bolts.........if that makes sense
PostPosted: Thu Oct 12, 2017 8:38 pm
Hi Peter, I'm trying to work out of changing from one setup to the other will alter the front track dimension?
PostPosted: Fri Oct 13, 2017 6:00 am
I don't think it does, I swapped mine 8-7 and didn't notice any change. Didn't actually put tape over it but looking at tyre/guard position I'd say the same.
Users browsing this forum: No registered users and 66 guests
