It is currently Sat Jul 19, 2025 3:33 am
PostPosted: Fri Sep 08, 2017 8:20 am
I would like to know how to identify Cooper 'S' pushrods from Mini pushrods or are they all the same?
PostPosted: Fri Sep 08, 2017 8:26 am
It is not hard to spot once you know. The 1275 pushrods are a different length to 850/998/1100 pushrods in that the 1275 pushrods are a 1/4 inch longer.
PostPosted: Fri Sep 08, 2017 8:31 am
Thanks Mick. Is there any difference in the stem thickness?
PostPosted: Fri Sep 08, 2017 9:07 am
They have always appeared to me to be identical except for length.
PostPosted: Fri Sep 08, 2017 9:22 am
I think I have tagged the pictures correctly. Please tell me if I am wrong.
PostPosted: Fri Sep 08, 2017 9:45 am
Yes that would be correct.
PostPosted: Fri Sep 08, 2017 8:58 pm
So, are all 1275 push rods the same shape at the ends as the cooper S.
in other words, there not Cooper S push rods but 1275 push rods ?
PostPosted: Fri Sep 08, 2017 9:42 pm
I will check my 1275 stock tomorrow.
PostPosted: Fri Sep 08, 2017 10:56 pm
I have "1275" pushrods with triangular ends like the bottom one in the above photo. So yes, there are 1275 non S ones.
but they bent after <1000 miles but that's another story...
Lillee - 1969 Morris Mini K
PostPosted: Sat Sep 09, 2017 9:09 am
I have 1-1/2 sets of original 1275 non- S pushrods, all look the same as the S ones in above pic. NOT triangular.
After Chong's problem above with new UK ones bending I would consider sourcing competition ones from APT in USA. Expensive but worth it, IMO.
PostPosted: Sat Sep 09, 2017 9:52 am
Thanks Mick
PostPosted: Sun Sep 10, 2017 2:46 pm
deleted
