It is currently Fri Jul 04, 2025 9:13 am
PostPosted: Mon Aug 07, 2017 5:24 pm
Would anyone know the part number or name for the rubber grommet for the metal fuel line passing through the metal bracket as shown? Could not find it anywhere. Otherwise imagine just a generic grommet?
Cooper S Mk2
Cooper S Mk1
PostPosted: Mon Aug 07, 2017 5:40 pm
Its just a generic grommet
PostPosted: Mon Aug 07, 2017 5:57 pm
Thanks Mick!
Cooper S Mk2
Cooper S Mk1
PostPosted: Mon Aug 07, 2017 9:03 pm
I have bought them before at Clark rubber - good selection.
PostPosted: Tue Aug 08, 2017 7:48 am
Neither of mine has the fuel pipe fixed in that fashion, nor can I see any advantage from a rigidity perspective. The combination of pipe and rubber fuel hose, properly clamped, works just fine.
PostPosted: Tue Aug 08, 2017 6:36 pm
Well, that's the way my original Cooper S was made. Would rattle if no grommet.
Cooper S Mk2
Cooper S Mk1
PostPosted: Fri May 08, 2020 9:27 pm
Hi all,
Revamping an old post which is relevant to a question I have regarding the fuel pipe grommet that fitted into the heater hose and hydro pipe bracket on the firewall.
I have added a few pics of the heater / hydro bracket from my MK2 S (right) and a 63 Cooper (left) and as you can see they are different grommets however the colour of the grommet is similar which leads me to believe that possibly back in the day the fuel system associated grommets were this brownish / reddish colour (the SU float bowl insulators are the same colour on my Mk2).
Now I understand that yes I could just find a black grommet that is 1/4" inside, fits a 3/8" hole and is 1/2" OD which will get me out of trouble but has anyone ever come across these brownish / reddish OE grommets, and is there an original part number for the MK2 version? I must admit I have spent waaay too much time googling this and came up with nothing....
Any help appreciated!
regards Gavin
Are they big? I like 'em big!
PostPosted: Fri May 08, 2020 10:40 pm
Thanks to a text from a mate, looks like red silicone is used to manufacture high temp grommets, might start looking for some of these in the size required. Stay tuned!
PostPosted: Mon Jun 22, 2020 5:25 pm
Grommet arrived and fitted, looks pretty good! i know, i know, small things, small minds etc, but if you applied that to every difficult to source part you replaced during the restoration you'd end up with a car that looks nothing like an original car. The Cooper grommet is different and I was unable to source anything like the original, but the Cooper S was a standard grommet in high temp material.
regards Gavin
PostPosted: Mon Jun 22, 2020 5:45 pm
Online
Good news, well done on your persistence.
Can you share the source to buy the grommet and part number for the benefit of others coming along behind you?
PostPosted: Mon Jun 22, 2020 7:28 pm
I have attached the website link, they are also available on eBay but the freight is the killer, having a contact in the USA that can send them over for much less helps, they ended up at about $2.50 each landed, I have a few left for anyone who is interested.
https://www.grainger.com/product/GRAING ... mmet-3MRP9
PostPosted: Tue Jun 23, 2020 9:14 am
and could possibly scuff its way through the soft tubing and cause a leak...
PostPosted: Tue Jun 23, 2020 7:03 pm
I'd be interested if you have any left please.
PostPosted: Tue Jun 30, 2020 1:26 pm
regards Gavin
Hi Gavin
PM Sent.
PostPosted: Tue Jun 30, 2020 2:15 pm
They were used throughout the factory for all the marques - MG's / Sprites etc. with a mix of black & red. Kits are available through some MG suppliers - at an unreasonable price though. Your option above is good bounce-for-buck.
Users browsing this forum: No registered users and 111 guests
