It is currently Sat Jul 19, 2025 11:40 pm
PostPosted: Tue Jun 27, 2017 10:05 pm
I think I have my head around this, can someone please confirm if this sounds correct:
Master cyliner has a line running to the top of the booster
Front of booster has a line running to the top of the 3-way fitting mounted on the firewall
Bottom of the 3-way fitting goes to the brake line that runs to the rear
Left of the 3-way fitting goes to fitting that has the brake switch and front left/right lines
Also, am guessing it will be much easier to install clutch hydraulics first then brakes after?
PostPosted: Wed Jun 28, 2017 6:24 am
Yes all you said is correct.
Fitting clutch slave cylinder with booster in is a pita. Fit that first.
I find a crowsfoot socket useful for tightening the MC mounting nuts.
PostPosted: Wed Jun 28, 2017 7:28 am
Thank you for confirming that for me doc
